08-13-2020
22:48
06:31
08-13-2020
22:48
06:31
Agenda won't sync when I sync my versa 2 (using iphone). All the permissions are on.
08-14-2020 06:31 - edited 01-10-2024 11:37
Hi there @drapearl, welcome to the Community Forums. Thanks for the details provided in your post about your Agenda app not syncing to your Versa 2 even after checking all permissions. I'll be glad to help you with this.
If your events don't appear, check the following settings:
If the steps above don't work, please confirmed that you've allowed the Agenda app to access your calendar and run in the background. Also, checked that you've adjust the app's permissions as described here: How do I install and manage apps on my Fitbit device?
I'm looking forward to your response, keep me posted.
Best Answer08-14-2020 06:31 - edited 01-10-2024 11:37
Best Answer01-19-2021 09:48
01-19-2021 09:48
When going to Fitbit settings, the calendar is not an option so I am not sure how to enable permission when it’s not visible in settings for iPhone.
