10-04-2019 02:11
10-04-2019 02:11
I have the new Versa 2 which is great except I have to keep logging in to Amazon daily on the Fitbit app to use the Alexa capability. I use the smart button held in to access the Alexa capability but every day it prompts me to set it up on the app. This works but it drops again at random times. I have tried just syncing again but this didn’t work. Can anyone help? Thanks
10-04-2019 10:16
10-04-2019 10:16
 Best Answer10-05-2019 13:40
10-05-2019 13:40
Ditto. It drops 3 or 4 times a day, but could he more - essentially whenever I go go use it it says
"Setup Alexa. Complete setup in Fitbit mobile app and sync device"
Have either of you had any improvements?
10-05-2019 16:38
10-05-2019 16:38
Mine is doing the same thing. Many troubles with this watch
 Best Answer10-05-2019 16:39
10-05-2019 16:39
no improvements, i have literally done everything and it keeps doing the same thing every day
 Best Answer10-05-2019 16:41
10-05-2019 16:41
No improvement
 Best Answer10-07-2019 02:09
10-07-2019 02:09
Improvement as yet. I did just open the fitbit app this morning and after a sync (automatic), the alexa app was working. This seems to be a small change but will see how this goes. I don't think I should have to do this everytime I need to use the alexa capability.
 Best Answer11-12-2019 11:23
11-12-2019 11:23
Same for me. Really annoying 😞
 Best Answer12-03-2019 14:28
12-03-2019 14:28
Is there any update to this please mine also logs me out daily, even though I tick keep me logged in to Alexa and keep updating Fitbit. Looks like it’s an ongoing issue, for so many to report it. Hopefully there will be a reply soon.
 Best Answer01-03-2020 05:36
01-03-2020 05:36
Ok, so the last update a couple of weeks ago seems to have delivered much improvement. I’ve not had to connect daily since the update. Logged in once and it has held. Fingers crossed that this has solved the issue. How’s everyone else? Check for updates if you haven’t done so in a while.
 Best Answer02-28-2020 19:40
02-28-2020 19:40
I can't even connect again easily. I got it working by uninstalling fitbit app and setting up the watch from scratch yesterday and now it says I need to set it up again.
 Best Answer05-08-2020 18:46
05-08-2020 18:46
It really sucks you posted this in October, and it's still a problem in May....
11-30-2020 20:24
11-30-2020 20:24
Now Almost December and still doing it. I have to log out and back in on the fit bit app and restart my fitbit almost daily. I purchased the versa 2 for the alexa integration and am really un happy!
05-19-2021 03:45
05-19-2021 03:45
Have had my Versa 2 for about 8 months and it started making me sign into Alexa every day, sometimes multiple times a day starting a few days ago, PITA
05-23-2021 16:39
05-23-2021 16:39
Yeah mine has been perfect until a few days ago too. Kinda shocking how it's been an issue for this long for others
05-25-2021 01:59
05-25-2021 01:59
Mine has started constantly logging out again too. Looks like it has become an issue again.
06-02-2021 02:43
06-02-2021 02:43
Same. Relly inconvenient. Easyer to just use google assistant on the phone at this point.
06-03-2021 02:16
06-03-2021 02:16
I have only had my Versa 2 for a couple of months and the Alexa has been working until the last week.
 Best Answer06-05-2021 15:55
06-05-2021 15:55
Ditto, if anyone finds a fix please post here.
 Best Answer06-05-2021 20:51
06-05-2021 20:51
It seems to happen on mine after every time I put the Fitbit on the charger for any length of time, or every time I restart my phone. Both affect it and it's super effing annoying.
