06-14-2023
07:55
06:40
06-14-2023
07:55
06:40
I am trying to get Alexa working on my Versa 3 but no luck. I have done the following:
I keep getting the error message “Connection Lost: sync device in Fitbit app. Let app run in the background to use Alexa”. I have done that, but still can’t get it to work.
Any ideas? Thanks!
06-19-2023 11:18
06-19-2023 11:18
@Lucy8735 , thank you for your reply ! To try to setup Alexa again, try the following:
Then try to set it up again.How do I set up a voice assistant on my Fitbit smartwatch?
06-15-2023 13:37
06-15-2023 13:37
@Lucy8735 A warm welcome to the Community ! Thank you for your message and efforts.
For the error message that you receive the following must be done:
06-19-2023 00:03
06-19-2023 00:03
Hi @JuanFitbit - thank you for replying so quickly! I have done all these steps but still get the “connection lost” message even with my phone right next to my FitBit and background app refresh enabled. Is there a way to reset so I can try to reinstall?
Thanks, Lucy
06-19-2023 11:18
06-19-2023 11:18
