05-14-2021 09:20 - last edited on 05-15-2021 05:41 by MarreFitbit
my fitbit must be automatically logging me out of my Alexa because I'm constantly going on my app logging back in!?
06-17-2021 14:28 - last edited on 06-30-2021 09:34 by KateFitbit
Hi everyone,
Thank you for the troubleshooting performed. Your feedback and comments are appreciated, we're always striving to provide a good service. Please verify to have installed the latest Fitbit app version (3.42.1 or above), this should resolve the issue.
Hope this helps.
05-04-2021 10:35
05-04-2021 10:35
Hello,
My Sense is dropping Alexa as the voice assistant. I have had to re-enable her twice in 2 days. I have done a hard restart on the Sense and forced the app to close more times than I can count just to reconnect to see my stats. I am very unhappy as I use the alarms and reminders and I count on them to work. I spent all of this money on a watch because I needed something that was dependable.
05-07-2021 08:42
05-07-2021 08:42
Same here with my Versa 3. Just recently it has been dropping the alexa connection, I reconnect and next thing I know it is disconnected again. Why is this happening now? Never had an issue before (have had the watch for months).
05-10-2021 05:43
05-10-2021 05:43
Same here. It worked several months without any issues and now every day I have to log-in another time to Alexa because it kills the existing login. This is really frustrating and I don't know why or how to fix it. All the other notifications work fine, watch and app are up-to-date. Running on Android
05-10-2021 07:50 - last edited on 05-21-2021 14:58 by SilviaFitbit
Since my latest fitbit update in May 2021, I have to set up my Alexa daily. Fitbit keeps logging me out. I've tried everything I can think of. I read where this was a problem in 2019 but didn't find any real solutions.
05-10-2021 08:11
05-10-2021 08:11
I'm also running android. I am extremely unhappy. I paid a lot of money for this and I need something that I can count on. If the alarms don't go off then I don't get up for work on time.
05-11-2021 00:11
05-11-2021 00:11
I now followed another user's suggestion to reboot the device, until now it's working, but it's less than 24h
The support wrote me:
Please still try the following steps:
- In the Fitbit app, tap the Today tab > Your profile picture > Your device picture.
- Tap Voice Assistant > Amazon Alexa > Sign out.
- Sync your Versa 3 with the Fitbit app.
- Make sure the Fitbit app is updated and force quit the Fitbit app.
- Restart your phone and also restart your Versa 3:https://help.fitbit.com/articles/de/Help_article/1186.htm.
- Open the Fitbit app and set up Alexa again.
We hope this helps!
05-13-2021 15:17
05-13-2021 15:17
@Vivcu2 Welcome back to the Fitbit Community. Thanks for the troubleshooting performed prior to posting.
I appreciate the research done and the details shared. I'd like you to confirm that this procedure was performed:
- Log out from the Fitbit app
- Clear the app cache
- Log back in, Set up Alexa and monitor its functionality
Hope this helps.
05-13-2021 16:00 - last edited on 05-14-2021 05:18 by MarreFitbit
Hi, in this last weeks my versa 2 automatically disabled Alexa forcing me to do the first start on the app. After I press "get started" appear an Amazon error page an then, on the versa 2, Alexa turn on to work normally. After some day, Alexa is again off...
Someone can help me?
05-14-2021 01:54
05-14-2021 01:54
Hi @SilviaFitbit,
it seems to be a general issue with Alexa on Android App version 3.41.2. I used Alexa since shipment of my Sense back in September 2020 without any issues.
Since this app update I always have to sign-in to Alexa again after restarting my phone and trying to use Alexa at my wrist.
05-14-2021 04:02
05-14-2021 04:02
Yes, I followed your advice as of last night. So far, this morning it seems to be working as it should. Thank you!
05-14-2021 05:12
05-14-2021 05:12
Hi @Vivcu2, have you already restarted your mobile? This is the moment where my Sense loses the connection.
05-14-2021 05:21 - edited 05-15-2021 05:40
Hi there, @Drake92. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note that Amazon Alexa is only available in certain languages and countries at this time. For more information, see fitbit.com/voice.
Before anything else, please make sure of the following factors which are required to install and use Amazon Alexa:
If those conditions are met, I'd recommend to log out from the Fitbit app, force quit the Fitbit app, reboot your phone and restart your watch. Then, open the Fitbit app, pull down on the screen to force a manual sync and try activating Amazon Alexa one more time.
Note that you can have only 1 active voice assistant at a time (Alexa or Google Assistant). To switch to a different voice assistant, first disconnect your active voice assistant. For more information, see How do I disconnect my voice assistant?
Hope that helps.
05-14-2021 05:30 - edited 05-14-2021 05:31
Yes, I have versa 2. I have used it twice this morning. So far so good!
05-14-2021 05:33 - edited 05-14-2021 05:34
Hi Marre, This issue is affecting me too since so many days. I raised the issue over social media and a case has been generated by the support team. I had even factory resetted my device but to no avail!
05-14-2021 05:42
05-14-2021 05:42
@Swatii_i Thanks for stopping by in the Community Forums and reporting this issue. Your time and efforts while troubleshooting this inconvenience are truly appreciated.
Since our Social Media team has already created a support case on your behalf to get in touch with our Support Team, please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon.
05-15-2021 05:40
05-15-2021 05:40
@Angelcowboy92 It's nice to see you around the Community Forums.
Hope that helps.
05-15-2021 05:53
05-15-2021 05:53
05-15-2021 06:00
05-15-2021 06:00
@Angelcowboy92 Thanks for sharing those details.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
05-15-2021 15:53
05-15-2021 15:53
@sancho90 Hi there. Thank you for the details shared.
I'd like you to confirm that this procedure was performed, as mentioned by @Vivcu2 this worked for her.
Hope this helps.
