06-16-2022
01:53
17:58
06-16-2022
01:53
17:58
My watch won't stop turning on and off. I have already did a factory reset 2 times now... It turns off then back on ... The screen comes on and I can use it as long as the screen Dosent go black. If it goes black and I touch the screen... It turns off again.... And repeat. Never been dropped. I do shower with it. Never had a problem until the other day. Anyone with some thoughts on this ? Thanks in advance !!
06-16-2022 04:42
06-16-2022 04:42
Just asking the obvious question, it's not the screen timing out and going to sleep and then quickly waking up when you turn your wrist? Otherwise if the watch has a good battery charge and keeps performing a full restart then it appears to be faulty.
I hope it's still in warranty and you can ask your retailer or Fitbit for a replacement.
Best Answer06-16-2022 05:20
06-16-2022 05:20
Hi James 291....
My screen time out is set for 10 seconds.... And the motion is turned off. Battery lasts a good 5 days .. and charges normally.
Best Answer06-16-2022 07:20
06-16-2022 07:20
Some of the recommended solutions on here suggest changing clock faces, in case the software within the current one is causing a problem. In your case I'm not sure it will help as you've already done a full reset, but it might be worth a try.
