01-01-2022
07:00
20:40
01-01-2022
07:00
20:40
Sigh
I’ve just received a replacement versa 3 and now this one, Alexa doesn’t listen… it just times out
ive searched the help forums and tried the following troubleshooting:
Log out Amazon, reboot FitBit, turn off Bluetooth, clear cache/cookies.
All WiFi is working correctly, Amazon account is live and working.
Please help, as I may end up going over to Apple Watch 😞
01-02-2022 22:05
01-02-2022 22:05
Hi,
I suggest you re-enable the microphone in Versa Settings. Go to Settings > Vibration and audio > Microphone.
If that doesn't work, check if your microphone isn't clogged with dirt/other objects. (The microphone is located on the right side of the device, opposite side from the button)
If it is clogged up, see here on how to clean it.
If none of those fix your issues, I suggest a factory reset.
Let me know how it goes. 👍
01-03-2022 04:20
01-03-2022 04:20
Sadly none of these worked 😢 😭
the mic wasn’t dirty either, it’s a refurbed one I only got out the packet a couple of days ago too
any other ideas?
Cheers
01-03-2022 23:00
01-03-2022 23:00
Sorry that those didn't fix your problems :(.
Might I ask, is the microphone working for other purposes on your Versa? (E.g. for Google Assistant, replying to messages, etc.)
If it does work for those other things, it's most likely a software fault.
Also, check if your watch is up-to-date. Go to Versa Settings > About Versa 3 > System Info > Version.
If your device is fully up to date, the version number should be 36.128.6.12. If the version number does not match, open the Fitbit App, tap your profile icon, then tap Versa 3. If an update is available, a pink button should appear saying something along the lines of "update now".
Thanks.
01-04-2022 01:33
01-04-2022 01:33
Thanks, I connected google assistant and the same thing is happening, it’s just not listening to me lol
Fitbit is all up to date and matches your version number
Do we have any more suggestions in the bank?
Cheers
01-04-2022 13:18
01-04-2022 13:18
I'm stumped 😅.
Only thing I can say is that since it's refurbished, it's very possible that permanent damage has been caused to the microphone itself.
You could try returning it, but I'm not that clear on Fitbit's return policy with refurbished products. You can read up about it here.
I understand you have just gone through this process, but what company refurbished your Fitbit?
Do they offer a warranty on your refurbished Versa? If they do, I highly suggest exchanging it for another one.
It sounds like you've had trouble with a previous Versa, was that also refurbished and from the same company?
As for fixing the problem at home, I'm out of ideas 😂.
01-04-2022 13:34
01-04-2022 13:34
Haha yeah I’m stumped too!!
It was FitBit that actually sent me this one as replacement for my original as it got stuck on the logo. When I received it, the packet said “refurb”… 🤷🏻:female_sign: I assumed I was getting a new one but obvs not!
I’ll contact customer services. Thanks for all your help 😊
01-06-2022 23:27
01-06-2022 23:27
Hmm, that's odd that Fitbit would send you a refurbished one.
Yeah, I'd say contact customer services, see what they can do.
Have a good day.
