The 3.00 versa update went smoothly on my versa with no noticeable problems or battery issues. I did want to know if anyone has updated that has Android 9 on their phone. I have a Samsung Galaxy s8 which is projected to get the Android 9 update in March, so wanted to make sure that versa is still playing nice with that OS version.
Hi, I'm on version 9 (Pie) of Android and the update went without any issues at all. It was finished within 10 minutes using WiFi. Even better with the new Firmware: logging sleep functions very well (which it did not in the previous version) and syncing with device is much smoother and faster. So, do not worry about that!
Best AnswerI've had Pie on my Motorola x4 for a couple of months now, and I've found Notifications to be inconsistent in that they don't always dismiss properly. There are times where I'll find notifications on my Versa that I dismissed from my phone hours ago or even the day before. Dismissing in the other direction, from my Versa, is a little more consistent though, properly removing from my phone most of the time. I'd be interested to see if anyone else has experienced this, as this otherwise worked perfectly when I was on Oreo. I haven't had any sync issues otherwise, except it seems like maybe syncing doesn't happen as frequently as it did on Oreo.
@MikeyP181 wrote:I've had Pie on my Motorola x4 for a couple of months now, and I've found Notifications to be inconsistent in that they don't always dismiss properly. There are times where I'll find notifications on my Versa that I dismissed from my phone hours ago or even the day before. Dismissing in the other direction, from my Versa, is a little more consistent though, properly removing from my phone most of the time. I'd be interested to see if anyone else has experienced this, as this otherwise worked perfectly when I was on Oreo. I haven't had any sync issues otherwise, except it seems like maybe syncing doesn't happen as frequently as it did on Oreo.
@AlessFitbit thoughts? Any other reports of Notifications being out of sync between the Versa and a phone running Android 9 Pie?
