03-26-2022
21:14
20:14
03-26-2022
21:14
20:14
Hi everyone,
Since Fitbit customer service is so abysmal and they don't seem to have bothered to create a filter for searching clock faces, I'm looking to you all for a good clock face recommendation. I'm looking for a relatively clean and simple design, and I need to see the time, steps, distance, and heart rate. A few other things is okay, as long as it isn't too busy and has the above specs. And even better is a clock face that is made by Fitbit so it doesn't drain my battery. Any help would be GREATLY appreciated. Thank you!
03-26-2022 21:41
03-26-2022 21:41
Hi @CaLupine - there is a search option in the Fitbit App, Gallery tile, Clocks, at the top then choose "By Fitbit" section and view all or enter the criteria in the search box, though it is OR.
You may have better luck using google search.
However as many of the clock faces will have all the options you request there will be a large number of hits.
Best Answer03-27-2022 11:32
03-27-2022 11:32
Will fitbit create the Boxy clock face from Ionic for Versa 3?? Please !
