05-10-2018
18:37
08:30
AlejandraFitbit
05-10-2018
18:37
08:30
AlejandraFitbit
Just got the new Versa and am excited. One issue, though. The holes in these bands are bot spaced like other bands. With all of my other Fitbit trackers I wore the large band. With the Versa, large is too big because its about 2 holes short. The small band fits okay but seems a little tight. Any way to safely add 2 holes to the Versa band?
05-10-2018 19:36
05-10-2018 19:36
Just spend $10 and get a 3rd party band that fits a wide variety of wrist sizes. Easier to swap out as well.
05-11-2018 08:53
05-11-2018 08:53
A warm welcome to the Community @SunsetRunner and @Bobled thanks for stopping by.
Regarding your question, yes, you add some some holes to your wristband. You can search for videos about how to do this. Just remember that adding holes to your Versa wristband will void your warranty if you purchased it from Fitbit.com.
If you need anything else, let me know.
