04-07-2018 11:22
04-07-2018 11:22
First off, the Versa has been terrific. I have had it since Monday afternoon, it made it to last night before needing to go on the charger (with a couple GPS connected exercises included in there), is very comfy, screen is crystal clear all the time even in very bright sun. But I have had a couple things of note:
Has anyone else with a Versa had any minor issues? All my problems have passed or have been resolved now, and I love this watch a ton.
03-30-2019 13:06
03-30-2019 13:06
I brought mine on Thursday. And it won't even do the update .I can't use it as it just will not do anything. Said syncing for 4 hours and then failed. So sad.
03-30-2019 18:11
03-30-2019 18:11
Good decision, I'm happy for you!
03-30-2019 18:12
03-30-2019 18:12
03-30-2019 18:37
03-30-2019 18:37
My wife gave me a versa lite to help me in my new lifestyle journey and I love it. The only issue I have is water not logging from my versa to the online dashboard and vice versa. It is supposed to he a know issue but I don't see it being resolved anytime soon.
03-31-2019 11:58
03-31-2019 11:58
04-04-2019 11:31
04-04-2019 11:31
@cjosic @SandraKay74 @PatCooper @Papermaster13 @Regina1961
I will gladly assist you with this.
@cjosic @SandraKay74 @PatCooper happy to hear that your device was replaced by Support.
@Jaydeevic1414 since it isn't syncing you can try can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here. Also retry the update by following these instructions.
@Papermaster13 as you mentioned this issue is being investigated and hopefully there will be a fix released for it soon.
@Regina1961 Lets address the battery issue first as this may affect all other features that you mentioned. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. The restart should also help with the bluetooth issues but feel free to follow the instructions in the previous paragraph too.
Finally which workouts are you doing and for how long?
Let me know how it goes.
04-04-2019 11:57
04-04-2019 11:57
05-05-2019 15:22
05-05-2019 15:22
Same here. Worked well since December (bit of syncing teething ) but now! Switched off bluetooth for a sec and now for 2 days it wont sync! Tried everything, uninstalled reinstalled, reset and still says bluetooth problems. Piece of s....
05-05-2019 21:18
05-05-2019 21:18
05-06-2019 03:18
05-06-2019 03:18
For all people having issues please see below for official response from fitbit.
Subject: Re: Fitbit phone inquiry: Versa - Not Syncing - #301xxxxx
Hi Paul,
It's my pleasure assisting you over the phone regarding your Versa that is intermittently syncing.
As promised, we have updated your case so that the Versa specialist would know the current status of your Versa when it comes to syncing.
However, upon their further investigation, they were able to find out that the cause of the intermittent syncing of your Versa is due to on-going issue with Android 9.0 which can't be fixed even with a replacement watch.
Furthermore, it won't be necessary for you to do the troubleshooting steps anymore to get your watch working normally since it is related to the Android software itself and are now working to identify a resolution as quickly as possible.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if there's anything we can do to assist you in the meantime.
Sincerely,
Raphael B. and the Fitbit Team
05-22-2022 18:02
05-22-2022 18:02
It’s junk. I should have purchased an Apple Watch. Never again. Total junk. BUYER BEWARE!
