02-14-2019 13:42
02-14-2019 13:42
Hi there,
My versa has a different calories burned count than my app which is messing up the overall calories I need to eat etc. My Versa says 2148 which I believe to be correct as in at 10,000 steps but my app is only showing 1200 calories burned even though it’s also showing 10,000 steps. Any suggestions??
thanks!
02-14-2019 17:08
02-14-2019 17:08
Hello @Kelligreen12. Welcome to the Fitbit forums.
It could be that your Versa just has not recently synced to the app to update the calories. From the phone app, click the icon of your Versa near the top right. Then at the top, it will show when was the last sync. You can force a sync by clicking the circle next to "Sync Now".
Let us know if that doesn't help, or if you other questions.
01-13-2020 09:26
01-13-2020 09:26
My versa 2 does not syncronize with the app on my phone! I tried logging off syncing but nothing works. I show I burned 2000 calories so far and my phone shows 600 calories less. Very frustrating I cannot fix it. Help me please
04-26-2020 17:34
04-26-2020 17:34
I’m having the same problem. My watch says I’ve burned 1350 calories and my app shows 685. It’s like it Max’s out at 800 a day. I have my goal set at 2500. And I sync it often.
