I Can't find where to add my email and it's even nore frustrating when about every 10 seconds the screen goes back to asking for the pin. I know I have to have it because of paymment but that is frustrating.. how can I change the time on that as well.
thank you
how do I get my email and texts? very simple
How do I turn off drive mode?
why does my screen need my pin # eveyer 10 seconds
Very simple questions
Best AnswerI don't think the Versa shows emails, though I could be wrong. Notifications depend on your phone.
https://help.fitbit.com/articles/en_US/Help_article/1979#choices
For texts, turn on notifications in the app, again, depending on your phone. See this article (follow the relevant links):
https://help.fitbit.com/articles/en_US/Help_article/1979.
To stop the Versa from asking for a pin, put it on your wrist and then enter the pin when asked. It shouldn't ask again until you take it off, or the next day, depending on how you've set it up. If you are using the device lock, or just a pin for Fitbit pay, the instructions can be found here:
https://help.fitbit.com/articles/en_US/Help_article/2250
The user guide is here: https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
I don't know anything about drive mode. Are you talking about adding a log entry for driving?
Best AnswerTrhr versa shows emails that's why I bought it
It has an outlook app too
The problem is that I think ibhit drive kide and do not disturb but I can't find where they are now
I guess you're referring to "do not disturb" and "drive mode" on your phone and it's effect on the Versa. Again, it varies, depending on your phone. See here:
https://help.fitbit.com/articles/en_US/Help_article/1979#dnd
On the Versa, if you press and hold the left button for a second or two, and then scroll to the right, you can turn notifications on and off.
Best AnswerThere's a thread about email notifications. Apparently you select whatever notifications you want from the app, including emails. (I don't use it - too many email addresses and my emails are too many and too long
https://community.fitbit.com/t5/Versa/Email-Notifications/td-p/2687826
Edit: Just checked my app and email doesn't seem to be an option for Windows 10 phones. Must just be Android and/or iOS.
