02-14-2019 00:47
02-14-2019 00:47
I just got my versa and I have completed the update. I can install clocks and change that. I can also view my notification screen just fine no problem. But as soon as I slide over to all the apps they are overlapping each other where I can only click one app which isn't installed. I have turned my Fitbit on then off, same with my phone problem still not fixed.
Best Answer02-14-2019 14:59
02-14-2019 14:59
Hi, try restarting your Versa multiple times in a row by pressing the left and right lower key buttons together untill you see the Fitbit logo and release the buttons. See if that solves this strange issue.
