11-24-2018 17:15
11-24-2018 17:15
Just opened and charged fully. It’s now asking me for a pin for which I have not even set up. Downloaded app and sync together. Can’t change pin or disable pin because I don’t know the original pin to begin with.
Very frustraded
please help
Best Answer11-25-2018 01:42 - edited 11-25-2018 01:43
This help article may be of some use to you.
I believe you can enter your pin incorrectly 10 times to prompt the option to unlock from your phone.
To unlock your device with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
11-25-2018 10:04
11-25-2018 10:04
When following @N8teGee's steps, the Fitbit App will ask for a pin or something.
This is whatever you use to unlock the phone, Fitbit wants to confirm that you are the owner of the phone.
