09-03-2019 05:02 - last edited on 09-06-2019 12:56 by LiliyaFitbit
Tried updating my Bitmojis outfit and it won't get past the 'connected preparing to teleport' phase. I know it's not the connection because every other clockface works and I can change the color on the bitmoji clock but the bitmoji itself won't upload. All I have is a spinning circle and it never starts teleporting. Bitmoji and Snapchat connections all work so I think it's a problem on Fitbit's end. Any suggestions? Nothing else I've seen in the forums has worked.
09-04-2019 19:03
09-04-2019 19:03
Welcome to the Fitbit Community, @jenny05.
I appreciate your participation in the Forums and sharing the details of the difficulty you're experiencing with updating your Bitmoji outfit. Thank you for your troubleshooting efforts and for confirming that Bitmoji and Snapchat connection is working. Some users find helpful the instructions provided in this post.
Give it a try and let me know how it goes.
09-06-2019 12:31
09-06-2019 12:31
No that didn't work. I found that post before and it did absolutely nothing.
09-06-2019 12:52
09-06-2019 12:52
Hi @jenny05, thank you for your reply.
I appreciate your time and efforts. Since the issue persists, I've sent your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
09-07-2019 19:57
09-07-2019 19:57
I have the same problem. Used to work but after the recent update it is stuck on preparing to teleport for hours
09-08-2019 08:15
09-08-2019 08:15
09-08-2019 09:51
09-08-2019 09:51
Same problem here, I have tried all of the suggested solutions as well.
09-08-2019 17:56
09-08-2019 17:56
Hello @Looceefur @jenny05 @janicki2005, it's nice to see you around.
@Looceefur thank you for joining the thread ans sharing that you're experiencing the same issue after the recent update. I would like to confirm if you've tried the following troubleshooting steps:
1. Please make sure that your watch doesn't have low battery.
2. Your Snapchat and Bitmoji accounts are connected (https://support.bitmoji.com/hc/en-us/articles/360001476203-Link-Bitmoji-with-Snapchat)
3. You've tried the suggestions in this post.
@jenny05 thank you for the input. I am sure our Support team is trying to help you in the best possible manner, please keep working with them.
@janicki2005 since the steps you've tried didn't work, I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
If you have any questions, feel free to let me know.
09-08-2019 20:13
09-08-2019 20:13
I'm having the same problem. I tried every suggestion I've found and verified all of the above. It sticks at "preparing to teleport" and nothing seems to work.
09-09-2019 19:59
09-09-2019 19:59
Mine also is having the same problem. Preparing to teleport, but nothing happens. I've tried all of the suggestions
09-09-2019 20:49
09-09-2019 20:49
I had the same issue and I finally got it to update but the emoji didn’t change and it was ‘stuck’. Now I can’t get it to work at all and all they offered me was a 25% discount on a new product since it is out of warranty. BTW the initial Versa had problems when they updated the app. They gave me a new one since it was under warranty but now they tell me the warranty doesn’t reset with the replacement and it reverts back to the original purchased date. So frustrating!
09-10-2019 04:46
09-10-2019 04:46
09-14-2019 17:12
09-14-2019 17:12
Mine did the exact thing. I changed my clock face to a different one then went back to switch it to bitmoji clock face. It’s like redoing the whole connecting to Snapchat/bitmoji all over again but it worked. Didn’t take long at all. I’m thinking it somehow disconnected from Snapchat. Good luck! Let me know how it works out. 🤞🏼
09-26-2019 19:33
09-26-2019 19:33
Me too
This is obviously an issue
Do something to fix it
Its obviously on your end
09-26-2019 19:34
09-26-2019 19:34
Ive done this twice
Hasn't worked
09-26-2019 19:40
09-26-2019 19:40
I did that a few times, even tried again after I updated the FitBit. Still nothing 😞
10-04-2019 09:51
10-04-2019 09:51
Has this issue been solved? Mine won't go past the preparing to teleport phase and all of my apps are updated so it's not an issue with bitmoji or snapchat or linking those two together
10-04-2019 10:02
10-04-2019 10:02
10-04-2019 19:10
10-04-2019 19:10
Hello everybody, thank you for participating in the forums. I am sorry for the delayed reply.
I appreciate the time each of you took to share the details of the issue, the troubleshooting done and your experience. Thank you for the efforts to resolve this and sharing the tips to help other users. I understand that this can be very frustrating and appreciate your feedback. Our team is always working on improving our devices and user experiences, and your comments are always welcome. I recommend trying the steps from this post as some users were able to resolve the issue after following them.
Please keep me posted.
10-10-2019 18:07
10-10-2019 18:07
Same thing is happening with my ionic and I just got it yesterday. All connections are good but it's stuck on teleporting
