09-03-2019 05:02 - last edited on 09-06-2019 12:56 by LiliyaFitbit
Tried updating my Bitmojis outfit and it won't get past the 'connected preparing to teleport' phase. I know it's not the connection because every other clockface works and I can change the color on the bitmoji clock but the bitmoji itself won't upload. All I have is a spinning circle and it never starts teleporting. Bitmoji and Snapchat connections all work so I think it's a problem on Fitbit's end. Any suggestions? Nothing else I've seen in the forums has worked.
10-10-2019 18:10
10-10-2019 18:10
01-18-2020 10:29
01-18-2020 10:29
I got the Bitmoji to show up on my clock face but it one pic of the avatar. the Clock face says connected to Bitmoji, but stuck at 'teleporting to smartwatch...' for a while now.
It does say it takes a while but been 45 min now. Everything is connected. What do I do next?
02-17-2020 11:01
02-17-2020 11:01
Try uninstalling and reinstalling the Fitbit app. That's what I did when it got stuck during teleporting and it finally worked. Hope it helps you.
06-24-2020 07:51
06-24-2020 07:51
Mine also is having the same problem. The teleport is blocked at 99%, but nothing happens. I've tried all of the suggestions. Could you please help me to fix this?
09-13-2020 19:36
09-13-2020 19:36
I tried all the steps a half dozen times, but the only thing that worked was a factory reset of the Ionic. A few days later I've made some changes and am stuck at "preparing to teleport." Too tired to do another reset.
02-21-2022 01:39
02-21-2022 01:39
Same problem on both Versa 2 and Ionic. Running FitBit App via latest Android. I have updated the Apps for FitBit, Bitmoji and Snapchat, and Bitmoji clock face is definitely the latest version. Followed all instructions several times.
02-22-2022 07:34
02-22-2022 07:34
I have the same problem. Followed all the steps in the post mentioned above, but to no avail.
02-22-2022 10:03
02-22-2022 10:03
I have the same issues just switched from Ionic to a sense, tried all the fixes nothing working so far, I am on iPhone 13 pro max
02-22-2022 10:20
02-22-2022 10:20
03-01-2022 11:46
03-01-2022 11:46
I am having the same problem. spayne729@yahoo.com
I uninstalled, reinstalled, deleted cache and data, force stopped, updated, changed passwords, factory rest, created new bitmoji and logged out of all Bitmoji, Fitbit and snapchat connects. FINALLY allowed me to connect > preparing to teleport and w just moving for hours. nothing.
03-01-2022 12:13
03-01-2022 12:13
Yep , same issues as me and many others. We can't all be doing it wrong surely? Is there anyone out there that has not had a problem I wonder? Maybe you could share your secret with us?
03-18-2022 21:29
03-18-2022 21:29
I just got a brand new Versa 3 and I can't get this clock face to work at all. It was a challenge just getting my snap and bitmoji even connected to my FitBit app, but it's just stuck on preparing to teleport. I even left it run overnight and still nothing.
04-12-2022 15:06
04-12-2022 15:06
I've had my versa 2 for less than 24 hours and I'm having the same issue with the bitmoji clock.
04-12-2022 15:59
04-12-2022 15:59
06-16-2022 15:40
06-16-2022 15:40
I'm still not able to get through the "preparing for teleport" phase. I'm so upset. My outfits weren't updating so I reinstalled and now I can see my Bitmoji at all. When I try to connect Snapchat I'm stuck teleporting. Any resolves? I reached out to Bitmoji and Fitbit. This is so upsetting because Bitmoji is why I love my Fitbit. It's insane that this isn't fixed yet. I also tried switch to 2.4GHZ for my wifi and that didn't work either.
06-17-2022 11:35
06-17-2022 11:35
Mine works now. just had to log out of every location that I had it and now it works.
06-17-2022 17:46
06-17-2022 17:46
How do I do that? I don't understand how you could be logged in multiple places. I thought you are just logged in the app itself.
08-05-2022 07:16
08-05-2022 07:16
Got a new Fitbit sense. Tried installing this watch face and followed the instructions. Still stuck on "preparing to teleport".
08-26-2022 15:26
08-26-2022 15:26
This issue is still going on in 2022. When will it be fixed? I'm having the same issue and yes I've tried the troubleshooting that has been suggested. I have uninstalled and reinstalled all the apps, restarted my phone and the Fitbit and still nothing.
11-28-2022 09:44
11-28-2022 09:44
Why is this problem still happening 3 years later. I got a new Fitbit and now cannot reload Bitmoji on my fitbit. Did everything suggestion yet still is a problem.
