05-23-2019 12:09
05-23-2019 12:09
Does anyone else have an issue with their music dropping out when they are outdoors?
When I run outside or walk trails around my local Y the music is constantly dropping out. The problem stops when you move the watch closer to the headphones but that seems crazy. I never have this issue inside on a treadmill.
If the issue was distance I can't understand why it would work differently inside and outside at the same distance.
Any ideas or is anyone else having this issue?
05-23-2019 18:25
05-23-2019 18:25
@Clynn2380 Normal. There's a lot of BT interference outside. It really depends on the place and devices used. Had the same issue with my Beats and my phone. Changed to Bose and helped. You can try changing headsets/earbuds, but this is known issue for BT connectivity not only Versa.
