Battery drain? Here's a tip-Versa
It worked for me and you can try this: lately for me, when it's charging, it takes a long time to switch from 99 to 100 then it drops from 100 very quickly. I kept it in the charger after it hit 100 for about 10 minutes and I noticed that it lasted longer. It stayed at 100 a lot longer. I suggest leaving your Versa in the charger for at least 10 minutes after 100%.😊 Hope this helps!
Moderator edit: added label
sarah, usa | versa, charge hr (retired)
4 REPLIES 4
Well if it works for you then it is worth others trying! Thanks for the hint ☺
Community Council Member
Helen | Western Australia
Hey @NellyG and @sarah_lin8, great to see you around.
I really appreciate the tip provided, I know a lot of people will find your post really helpful. If you need anything, do not hesitate to post it.
Keep the stepping up! Woman Very Happy
I went to bed at 9:30 last night and woke up to drained battery. Saw this morning at 10:30 email came in telling me it was low. It went from low to drained sitting on my night stand!!! Help! I'm leaving on a trip in a couple weeks and don't want that to happen again. I've had it for a couple months and this was the first time.
I just gave up on my versa ever lasting any longer than a few seconds at 100%. Even leaving it on the charger for 10 mins or so, as soon as I check the screen it has already dropped to 99%. But on the good side, so far, my versa uses between 15-20% daily with exercises and on and off Bluetooth and constant manual syncing so I’m happy.
