10-13-2018 22:20
10-13-2018 22:20
For 6 months, my Fitbit Versa was draining about 12% per night consistently, thus lasting 5 days or more.
Roughly 10 days ago, it suddenly began draining 21% per night consistently. I changed nothing in any
settings. It is paired to a Pixel 3 (yes I work for Google), and I'm using the TH3 watch face. But again,
I changed nothing at all in my configuration. This can't be a battery getting weaker, because the doubling of battery drain happened so suddenly. What should I do?
10-13-2018 23:04
10-14-2018 12:02
10-14-2018 12:02
That's exactly when the double drain began. (I am now running v2.80.1 (20213324).)
So it's the app version on my phone, not the firmware on my watch, that needs rolling back?
How odd! What are they doing - syncing 5x as often?
So to which version should I roll back? On application mirror sites I see v2.80 (October 1),
v2.79 (Sept. 19), v2.78 (Sept. 6), and older versions. Any suggestions?
Dear Fitbit - if you have a suggestion, I would love to hear it, before I try this roll-back.
10-15-2018 20:47
10-15-2018 20:47
@marclevoy my best guess is versa has trouble syncing so keeps trying and trying and trying draining your battery. You could try to turn off all day sync setting in the Fitbit mobile app and see if it helps. If not I would downgrade the mobile app. Now which version is a tricky question. If the previous version worked for you fine, then roll back to it. In my case, all recent versions of the software were a disaster. Versa would not sync, mobile app would drain my phone battery and forget about notifications. I always had to roll back to the most stable version for me - version 2.74. perhaps you're extremely lucky and your versa doesn't have issues. In that case roll back one version. ☺️
10-25-2018 09:02
10-25-2018 09:02
Hi,
I'm facing the same problem, the battery drain happened so suddenly throughout the past 10 days, my Versa is paired to Blackberry Key2 (Android version 8.1.0) although I didn't change any setup in the mobile app nor the watch.
any suggestions?
