Battery draining at faster rate
ANSWERED
My battery has been draining at a crazy rate. This has happened in the last few days. Last night it was at 85%. This morning it was dead. I haven't changed anything on it and dont listen to music with it.
1 BEST ANSWER
Accepted Solutions
Hi, try restarting your Versa 4-5 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the keys. Charge your Versa and see if the drainage problem is solved. when it's not solved by this, contact Customer Support and ask for a battery test.
9 REPLIES 9
Thank you! Will try it now.
Same ! I had a full charge yesterday around 3pm and I woke up today 7:42 am with 56%.  I didn’t work out, no music, no water or food logging.....I mean I didn’t leave the house. So its safe to say this is the worst Fitbit product I’ve ever owned.
The fix that I received seems to have worked. Try it!
Hi, if my fix helped you solve your problem, see my signature and mark the fix as an accepted soltution. This will help other users with the same problem to find it easier. Thanks!
Thank you, but unfortunately it did not work for my Versa.  I will have to contact Fitbit directly.
Done! Thank you so much!!
Thanks very much, that's whu I'm around to help users with problems the best way possible!!
How do you do this with a Versa Lite? There is only 1 button and I am having the same issue. Thanks in advance.
