Battery draining fast, charging twice a day.
Hiya everyone,
I was just wondering if anyone has had problems with the battery life in their Versa. I only bought it in May and it dies overnight and once I've recharged it in the morning it only lasts til maybe 4pm. Tried a few things like restarting it etc but nothing has worked.
5 REPLIES 5
Hi, when restarting does not solve your problem, you can try two other things:
1. Perform a Factory Reset.
2. Contact Customer Support and ask a battery test.
Personally I would choose option 2 cause I think you have a battery problem. Regards kuzibri
Thank you, I'll try a factory reset tonight and if it doesn't work I will contact them tomorrow. Donna.
The same thing is happening to my Versa.
Thanks for sharing.
Hi Donna, remmber that your synchronize watch with the Fitbit app before doing a FR, otherwise you will loose valuable data. Regards kuzibri
