04-13-2018
20:01
12:52
AndreaFitbit
04-13-2018
20:01
12:52
AndreaFitbit
Hi,
When my Versa charged to 100%, I purposely left it on the stand for 20 mins more. But it shows 99% within one min after I started to wear it. Any ideas? Defective?
01-07-2019 04:50
01-07-2019 04:50
Hi, Once they deemed you needed a replacement, did they offer to replace or must you pay for a new one. I've had my Versa less than 4 months and the battery has started draining fast. It was at 100% at 7:30pm and by 5:30am, it was down to 51%.
01-07-2019 04:55
01-07-2019 04:55
01-07-2019 04:57
01-07-2019 04:57
01-07-2019 05:16
01-07-2019 05:16
01-07-2019 06:46
01-07-2019 06:46
01-07-2019 08:42
01-07-2019 08:42
01-08-2019 20:25
01-08-2019 20:25
I have a similar situation. If I leave my Fitbit Versa on my night stand all day, the battery has better battery life. But, if I wear it the Versa's battery drains completely within half a day. I have to wear my old Fitbit Blaze now because I can not depend on the Versa's battery life. I have only had the Versa for maybe two months. The battery problem started after I had loaded music files on it. I am wondering if the music is playing because it is always near my iPhone when I wear it. Maybe my iPhone is always playing music on my Versa?
@KrisD. wrote:
Thanks, I have reach out to support and they deem that I'll need a replacement.
Sent from Samsung tablet
01-09-2019 04:44
01-09-2019 04:44
01-09-2019 05:22
01-09-2019 05:22
01-11-2019 18:37
01-11-2019 18:37
Glad to see this in a weird way - seemed like my Versa (about 4 months old) was losing the charge fast in the last week. Last night charged to 100% and it was at 25% in about 20 hours and I don't have any music or extras on it. Will be getting in touch with support.
01-11-2019 18:53
01-11-2019 18:53
01-11-2019 19:49
01-11-2019 19:49
01-12-2019 10:31
01-12-2019 10:31
01-18-2019 16:45
01-18-2019 16:45
Thanks! I have been having issues for the past few weeks with my battery life. I will be trying these solutions!
Other than the battery.. I love versa!!
01-18-2019 17:07
01-18-2019 17:07
01-18-2019 17:28
01-18-2019 17:28
Recently experienced rapid battery drain which I am attributing to an update to the watch face I use. I went to the settings and turned off the QuickView and it turned things around. Went from the battery charge lasting 24 hr to using just 24% in 24 hrs.
01-18-2019 17:29
01-18-2019 17:29
Recently experienced rapid battery drain which I am now attributing to an update to the watch face I use. I went to the settings and turned off the QuickView and it turned things around to the point where it went from the battery charge lasting about 24 hrs to using just 24% in 24 hrs.
01-18-2019 17:36
01-18-2019 17:36
01-18-2019 17:45
01-18-2019 17:45
After going through some checks Fitbit determined there was something wrong with my battery and a replacement is on it's way. The customer support was great.
01-18-2019 21:38
01-18-2019 21:38
To those of you experiencing battery drain and running 3rd party clock faces... Some clock faces have quite frequent refresh rate. They run in the background draining your battery. Just go to Permissions of the clock face and disable run in the background. This will apply especially to stats heavy clock faces. Alternatively, you can change your clock face to one of Fitbit originals to see if that changes anything.
