04-13-2018
20:01
12:52
AndreaFitbit
04-13-2018
20:01
12:52
AndreaFitbit
Hi,
When my Versa charged to 100%, I purposely left it on the stand for 20 mins more. But it shows 99% within one min after I started to wear it. Any ideas? Defective?
12-29-2019 17:36
12-29-2019 17:36
12-29-2019 17:41
12-29-2019 17:44
12-29-2019 17:44
12-30-2019 07:28
12-30-2019 07:28
I agree I have called 4 times in the last few months and they kept saying that they are fixing the bugs and I should wait. My batter is fine after they replaced it 6 months ago but now because of the IOS updates in the last 4 months I got get calls or texts the latest solution they tell me is I should switch from iPhone to android give up a $1000 phone that works ABSOLUTELY fine and move to android so my Fitbit can work what stupidity! That put me over the edge
12-30-2019
07:33
14:07
JuanFitbit
12-30-2019
07:33
14:07
JuanFitbit
I have a versa and have gone through the battery draining issue also. I
switched over to an Apple Watch and I love it. The new ones that recently
came out are sleeker and not as bulky as before. I would take the jump if
I were you!! I really loved the purple color of my versa but that Watch
sucks
Shelly "Happiness is not something you postpone for the
future; it is something you design for the present." Jim Rohn
Moderator edit: removed personal information
12-30-2019 07:42
12-30-2019 07:42
Went through the same issue. My original versa got replaced three times by the store before they finally terminated that program. That third original versa ended up lasting about a year and a half before finally succumbing to the battery issue. When I called Fitbit, they said there's nothing they could do and sent me a 25% off certificate for another watch, however since it was around Christmas and their promotional price was the same as 25% off that meant that there really was no additional incentive (same low price).
I did weigh the pros and cons of the Apple Watch, but ultimately I went with the Versa 2 because:
1. Fitbit does have far better analytics and fitness tracking than Apple
2. I wouldn't use most of the Apple Watch apps/features
My logic was why pay for a watch with limited fitness tracking capabilities and that needs to be recharged daily (no sleep tracking either)?
So for the Versa 2 has been great and no issues. Its a bit sleeker (cleaner and crisper colors), faster, and I'm very happy with it.
Just my 2c
12-30-2019 07:51
12-30-2019 07:51
12-30-2019
08:42
14:07
JuanFitbit
12-30-2019
08:42
14:07
JuanFitbit
Your opinion helps a lot!
12-30-2019 08:56
12-30-2019 08:56
12-30-2019 17:42
12-30-2019 17:42
I would have gone with the versa too but was very disappointed with the customer service have been with Fitbit for do long and they were so rude these last 6 months so figured with google taking over and the transition it might get worse so I switched to appke
12-30-2019 17:54
12-30-2019 17:54
01-03-2020 11:51
01-03-2020 11:51
My charge 3 dies within 24 hours of charging plus my charger chooses when it will charge my watch. What can I do to get it to work?
01-03-2020 11:54
01-03-2020 11:54
01-04-2020 08:58
01-04-2020 08:58
I have the same issue. Won't last a day. First it lasted 3 days, which I was told would last up to 7 days before charging. I've already shut down (always on display), don't use any of the apps, except to sync to my phone and get text and phone calls (of which there are few during the course of a day). What gives?
Charged it overnight. Versa 2 displayed 100%, phone displays 60%. Put it on and in 15Mins. the battery drained down to 64%. I literally walked out of my house and up two blocks! The only apps I use is the weather app, text messages. The clock faces are worthless now because you state using them causes battery drain. What good is it then? Help!
01-04-2020 09:19
01-04-2020 09:19
01-04-2020 10:11
01-04-2020 10:11
01-04-2020 11:09
01-04-2020 11:09
01-04-2020 12:03
01-04-2020 12:03
01-04-2020 12:08
01-04-2020 12:08
01-04-2020 17:27
01-04-2020 17:27
