12-19-2018
12:19
05:55
LanuzaFitbit
12-19-2018
12:19
05:55
LanuzaFitbit
I have my versa for quite some time now, and all of the sudden the battery dies within a day where I use to get 4/5 days out of it.
I have done factory reset and still drain within a day, I only use fitbit clock faces cause I have seen complaints that using other creators faces may drain the battery quicker so I haven't been using other faces other than the fitbit ones.
This is very frustrating!!
Best Answer12-20-2018 05:59
12-20-2018 05:59
Welcome to the Forums @Versafan.
Thanks for bringing this up, and trying to change clock faces to get the battery to last longer. We'll be happy to help you. I have moved your thread to the Versa board as I think it is better suited for it.
I have reached out to our support team so that they can help you get this situation resolved. They should be getting in touch with you soon. Be sure to keep an eye on your email's inbox or spam/trash folders in case the mail is filtered there.
Let me know if you have any further questions.
