12-09-2021 11:48
12-09-2021 11:48
So, been disappointed with my Versa 2 ever since the heart rate stopped working (or whatever sensor detects being on my wrist) shortly after warranty. Notifications come and go but I gave up on that feature too. All of a sudden the watch starts receive all my phones notifications and then that evening updates, now my watch's battery life is no more then a third of what it was.
Is the all of a sudden battery performance the result of the update? I think about hetting the sense, but wonder if that'll too be a mistake
12-09-2021 22:26
12-09-2021 22:26
Hi @Jarubell - if the battery performance changes suddenly after an update then that is mostly likely the cause.
It is also most unlikely to be a watch issue.
You probably have the best watch so changing might be a costly mistake. Check on the forums to see other people's experiences.
However there are things you can to check and extend battery life .
If the Fitbit App seems to be the cause, try temporarily turning off Bluetooth and restart the watch and see how well the battery performs.
12-11-2021 18:52
12-11-2021 18:52
Thank you, I'll try the BT trick tonight
