09-23-2019
01:10
05:27
JuanJoFitbit
09-23-2019
01:10
05:27
JuanJoFitbit
Hi all .. just started using my new versa lite and I seem to have to charge it every day, this can't be right? Thought I would get 3-4 days at least per charge .. brightness level etc is at normal, just wondering should I return and exchange for a new one.
Best Answer09-24-2019 05:25
09-24-2019 05:25
@SunsetRunner welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since its battery is not lasting as long as it should.
I'd like you to try the tips that are listed in this help article. These tips are helpful in order to improve te battery level of your Versa. After this, monitor the battery's behavior of your Versa and see if the issue gets fixed.
Keep me posted on the outcome! 😀
09-24-2019 05:25
Best Answer09-24-2019 06:44
09-24-2019 06:44
Thank you for reply i will try these tips you have linked and see how I get on much appreciated
09-25-2019 09:10
09-25-2019 09:10
@SunsetRunner You are very welcome. I appreciate the time you will take to try the recommended troubleshooting steps.
Don't hesitate to let me know how it goes! 😀
