02-15-2019 19:15
02-15-2019 19:15
hello dear I would like to know how to make the battery last for more than 12 hours, I have already followed the protocols and even then it does not last beyond 12 hours even with the bluetooth turned off without receiving notifications it is using for only 1:30 during the time I am in the gym .
02-16-2019 00:05
02-16-2019 00:05
@Rochaanna1 I would recommend performing a factory reset (restoring Versa to factory defaults). This will wipe your Versa, so please sync first. You will also need to delete your tracker from your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a replacement device in the Fitbit mobile app. Good luck!
