08-18-2022
08:20
17:25
08-18-2022
08:20
17:25
I'm totally blind! I can use Alexa on my Versa 3 to start a workout! But being I'm totally blind, I can't stop the workout being it requires you to touch the screen to go through a few different screen to tell the watch you are done with your workout. I would like to be able to at least start Alexa on my watch and tell it to Finish workout and have it just stop without having to do anything with the watch. But maybe have the watch speak something to say Your Workout has been finished to confirm that the Alexa command worked. Just showing something on the screen will not work for a totally blind person. I even tried going into the Fitbit App on my Android phone and didn't find anyway to tell if a workout was in progress on the watch. So couldn't stop it even that away. The only way I found to stop a workout and that could have just been by luck! Was to press and hold the side button and forse a restart on the watch. Like I said, you can start a workout with Alexa but can't stop one.
08-18-2022 09:38
08-18-2022 09:38
@BlindUser I gave you a link in your battery life thread. The Disability Support team might be able to help you with this question, too.
Laurie | Maryland
