04-08-2018 10:58
04-08-2018 10:58
Hey everyone,
I was wondering if anyone has suggestions for tempered glass screen protectors or cases to protect the body of the watch. A lot of the products on Amazon say they won't be available for a little bit yet and but I want to order something a.s.a.p. I basically want someway to protect my watch without drastically changing its look. I have the charcoal special edition. Any suggestions would be greatly appreciated!
04-08-2018 11:29
04-08-2018 11:29
I ordered this off of Amazon, I typically don't use tempered glass unless its for my phone just because it looks bad. I suggest not using tempered glass if you want it to look like it has nothing on it or like the orginal (if that makes any sense). As for the body protector, I wouldn't suggest it either just because most of them are bulky. If you treat your Fitbit with care there's no need for a body protector. That's my opinion.😊
04-08-2018 11:25
04-08-2018 11:29
04-08-2018 11:29
04-08-2018 11:36
04-08-2018 11:36
I would be concerned about affecting the sensitivity of the touch screen.
04-08-2018 12:05 - edited 04-08-2018 12:33
Thanks, everyone!
05-12-2018 09:04
05-12-2018 09:04
Are the plastic edge protectors annoying to remove when charging?
05-12-2018 10:26
05-12-2018 10:26
Unfortunately they are... at least it takes a while each time removing the bands and putting on again. But if your patience is strong enough it is a good way to protect your watch from damage 😉
