01-17-2020 00:48
01-17-2020 00:48
I have a Versa 2 and it stopped syncing to my phone (Huawai P30 pro) and the sync option disappeared from my app, so unable to sync to phone. I now a big red x on fitbit screen saying Data not cleared, Sync and try again, which I am unable to do. I have reset the phone and turned Bluetooth off and on again and turned fitbit off but x remains and I am unable to set up another phone as the phone will not find my fitbit!! I can't even reset the fitbit as there is no reset button like on a phone.Please can anyone help if they have had the same problem and restored it .. TIA
01-17-2020 18:28
01-17-2020 18:28
Hi @SunsetRunner,
Please see the moderator post here. This will factory reset the Versa 2.
If you don't want to factory reset the Versa 2, you can hold the button down for more than two seconds when you see the Fitbit logo appear and the device will just restart.
one cruise ship at a time!
Best Answer01-17-2020 18:59
01-17-2020 18:59
Hi @SunsetRunner
I had the same issue with my Fitbit versa (version 1) and I contacted Fitbit for help and they told me this, this has fixed my Fitbit and it is now up and running smoothly. Let me know if this helps:
Let's start by:
While your phone is off, restart the Versa like this:
After this turn on your phone, open the app and log in to follow this procedure:
If you're still unable to set up, try the troubleshooting steps below in this specific order.
Best Answer07-10-2020 19:00
07-10-2020 19:00
I'm having the same identical problem! I'm ready to throw it!!
