04-19-2018 01:07
04-19-2018 01:07
Hi All,
I wonder if you can help. This morning i cycled into work and being really keen to try out my shiny new versa. I was gutted to find that it hadn't tracked my GPS position. Playing with it just now - it still just remains at "Connecting". I am sitting with the phone in front of me and as far as i can see. everythings enabled, connected up and the software is up to date on both my phone and versa
Device: Fitbit Versa
Software Version: 32.32.4.19
Phone: Samsung S8+
Software Version: 8.0.0
Fitbit App: Version 2.69
This was one of the main features i was really looking forward to having back. I had an apple watch previously but moving to Android killed that so this the next best solution. All very seemless with apple.... not finding it as easy with this!
any help you can provide here?
Cheers
04-19-2018 01:12
04-19-2018 01:12
I should also add that
the watch connects to the phone no problem, it syncs up fine and tracks my steps, sleep etc. just the excercise part/GPS im having an issue with here
04-22-2018 17:47
04-22-2018 17:47
I have been having the same problem too.
I am using iPhone 7. It connects no problem. But with the Gps it says connecting and doesn’t ever connect. Help to
04-22-2018 18:06
04-22-2018 18:06
unpairing mobile track in the app helped my GPS connect and the map\distance is also correct now. Worth a try.
04-22-2018 18:15
04-22-2018 18:15
I've found that I need to have the fitbit app open on my iPhone for the connected gps to work. It doesn't have to be onscreen, just opened in the background. if I accidentally close the app in the middle of the exercise, my versa looses connection to the gps, but it reconnects shortly after opening the phone app again. It's a minor inconvenience, bit I'm just happy it works and is an easy work around.
04-22-2018 18:41
04-22-2018 18:41
I found that by rebooting my phone and my versa it worked just fine. Just have to make sure it gets connected before starting.
04-22-2018 18:45
04-22-2018 18:45
Forgot to mention that I also use the 'Keep Alive Widget' - that might be helping as well.
05-02-2018 05:37
05-02-2018 05:37
Same for me, really disappointing that I buy my first Fitbit and was looking forward to it only for connected GPS to stop working.
Please help.
05-03-2018 11:44
05-03-2018 11:44
I am also having this problem, I have a I Phone 5s, connects to phone no problem, tracks everything and otherwise works great, but has serious issues connecting for exercise and just hangs on "connecting..." Turning off both devices and back on does work, but I shouldn't have to do this every time I want the exercise (specifically biking for me) to work.
05-25-2018 05:11
05-25-2018 05:11
ChadDennis - Were you able to find a solution? I went to spin this morning and left my phone in the car. The entire time, it counted calories, but didn't actually track miles. Any advice?
05-25-2018 05:11
05-25-2018 05:11
It also said "connecting" the entire time.
06-04-2018 14:54
06-04-2018 14:54
I had the same issue but now seems to have resolved. Rebooted both Versa and iPhone. Also seem to need to ensure connected before starting the workout.
07-05-2018 00:26
07-05-2018 00:26
Hi! I had the exact same issue yesterday with my Fitbit Versa, when I first wanted to try the tracking while biking to work. I use Samsung S7. The solution for me was the following:
In "Location" menu, under "Improve accuracy" turn on the "Bluetooth scanning" option as well next to the "Wi-Fi scanning".
After this setup my Versa connected immediately and today my ride was mapped!
07-03-2019 21:40
07-03-2019 21:40
GPS is not connecting when I use the bike exercise. Can anyone help.
09-21-2019 12:26
09-21-2019 12:26
After three days of trying to solve the same problem - Versa Lite frozen on connecting to GPS while cycling/walking or running - I have managed to make the app working by rebooting the watch and switching on Bike while sitting with my Fitbit app open. There is a post below suggesting it. And it magically has unfrozen my watch. Hopefully for good!
02-29-2020 22:26
02-29-2020 22:26
I think I solved this (didn't see this in any of the replies so if I missed it, sorry!)
Go to Fitbit app and
account > advanced settings> automatic location
I turned the automatic location "on" and it immediately went from "connecting" to a distance value. I think the app has to be open though.
05-15-2020 19:27
05-15-2020 19:27
I am having the same issue very disappointed
05-25-2020 17:41
05-25-2020 17:41
I figured it out for my Versa Lite!!!
I have an iPhone. Go to Fitbit settings on your “Phone“, Select Location, choose Always, then open the Fitbit app and leave it on during your exercise. It takes a couple of seconds to connect to the Fitbit, but mine connects each time now.
09-27-2020 15:36
09-27-2020 15:36
I had the same problem. I tried all the common suggestions - rebooted phone and Versa, connected before I tried to start the Exercise app, etc.
The only thing that seems to work is leaving the app running on my phone. I don’t have this problem when I run with it.
