02-28-2020 15:09
02-28-2020 15:09
When I do a "Ride" exercise, the distance is grossly under-reported; it said I'd gone 0.06 miles when it was actually >13 miles. Versa 2 is synced to my Android phone, they regularly show notifications, status, etc. And when I view route in Strava it looks fine on map, just the distance is way off.
No such problem when I do a "Walk" exercise, distance looks correct.
02-28-2020 15:43
02-28-2020 15:43
Mine does the same thing on runs. There has been no fix to this. Customer service is terrible. Im going to try Garmin as fitbit is garbage.
02-28-2020 16:40
02-28-2020 16:40
Walk uses your step count and stride, neither of which is available on a bike.
02-28-2020 17:03
02-28-2020 17:03
02-29-2020 00:18
02-29-2020 00:18
For me, when I record a bike ride, it does use GPS and does measure the distance.
I responded to the comment comparing a bike ride to walking and that it should be just as easy to measure the distance.
When walking the tracker is using fixed constants. When using GPS the signal depends on the environment (clouds, trees, etc) and your referencing a your position from a point that is moving at several times the speed of sound. There is a lot more timing and math invoked. Even you cars GPS at times has issues locating it's position but assumes your on a road.
03-03-2020 12:44
03-03-2020 12:44
I agree there's a lot more computation to get distances using GPS, my point was that it can and should be doing it. But it under-reporting distances by 50x or more!
Customer Support has not been helpful in resolving this. If it works for you, maybe I have a defective unit.
03-03-2020 15:22
03-03-2020 15:22
try and get a replace fast, if it is over a year since buying it they will not help you.
I bought a garmin and for the same money it is 4x better and actually records distance accurately.
