09-15-2018 16:45
09-15-2018 16:45
I turned on the "Bike" option under "exercise" but by the end of it all, it wasn't recording the distance and there is no GPS mapped. Pls help. How can I set it up? Thanks
Best Answer09-15-2018 17:18
09-15-2018 17:18
Versa doesnt have inbuilt GPS to get a map you need to take your phone and use the app to start the exercise, however the GPS option is not there for bike, so you would have to use run or hike. If you want to try this, in your app tap the exercise tile (running man) then tap the stopwatch icon in the top right. Then select the Tracking tab and you can set it up there. Come back if younjave further questions.
Helen | Western Australia
09-16-2018 00:06
