01-30-2020
15:22
10:19
01-30-2020
15:22
10:19
I recently was using the Bitmoji clock face. It caused me to lose a day of battery life, from 6 to 5. So, I kept it saved. I noticed that battery drain was still happening. Charged it 2 days ago & now it's already down to 76%. So, I removed it. Has anybody notice that happening?
01-31-2020 11:56 - edited 06-07-2024 05:39
Hi @RottieLover, thanks for stopping by. Thanks for the details provided and letting me know that you've removed the Bitmoji clock face in the meantime.
We haven't received reports of this issue. However, I'd like you to try the tips that are listed in this help article in order to improve the battery life of your Versa.
01-31-2020 14:38
01-31-2020 14:38
I've already recharged. My quick view has been off since I got my versa. Since the recharge, battery is currently at 91%. I'm going to monitor it for the week & if I still notice anything, I'll get back in touch for a battery check.
01-31-2020 15:04
01-31-2020 15:04
@RottieLover as fun as the Bitmoji CF is, there have been various problems reported with that CF, one of which is battery drain. I used to use that CF but I don't anymore. Try CF "Minimal Style". It has loads of colors to customize and it does not drain the battery.
01-31-2020 15:13
01-31-2020 15:13
Sure thing @RottieLover. Keep me posted, I'll be around. 😉
01-31-2020 17:55
01-31-2020 17:55
@SunsetRunnerI usually use FitFace, with my own design. Back to using. You'd think that if the Bitmoji CF is just being stored, it wouldn't use battery. Apparently, I was wrong. Seems like battery is back to where it was. 😀
