06-09-2018 15:15
06-09-2018 15:15
Have any of you found swim-proof headphones that will work with a versa?? I would really love to listen to music while swimming!!
06-09-2018 21:52
06-09-2018 21:52
Best Answer06-10-2018 01:54
06-10-2018 01:54
yesterday I was in the pool with Versa and Jabra Elite Sports and can confirm that they work great if you dont put your watch under water. Then music will stop playing immediately
06-10-2018 02:26
06-10-2018 02:26
Bluetooth doesnt work under water, so you might have problems with all that water around!
Helen | Western Australia
11-01-2018 18:05
11-01-2018 18:05
I just returned my xFryo buds because they didn’t work as advertised. I wouldn’t recommend anyone to but them. I was in the pool on Sunday. It was difficult to get them to stay in. After struggling to get my cap on, as soon as I dipped my head underwater, the buds decided to stop the music and make a call to the last number that called me. I had to jump out of the pool to end the call from my phone. So many bugs they haven’t addressed in version 2
11-01-2018 18:28
11-01-2018 18:28
You will not be able to listen under water. The Bluetooth does not work when your watch is under water. Also, the headphones would probably get water clogged anyway.
01-13-2019 08:04
01-13-2019 08:04
Love the idea though! Keep asking as they might invent a way!
Best Answer02-22-2019 09:14
02-22-2019 09:14
Hi,
So you cannot listen to music when you’re swimming? What an absolute bummer!
Fitbit do not make that clear, do they.
Very disappointing indeed.
Thanks for the info.
Glad I didn’t waste money on earphones now.
02-22-2019 09:14
02-22-2019 09:14
That’s a shame. Thanks for the info.
Gutted!
Best Answer05-08-2019 00:35
05-08-2019 00:35
Do any connect with WiFi? The kind of wifi that just connects 2 devices together eg camera and phone.
Best Answer05-08-2019 00:43
05-08-2019 00:43
Best Answer02-28-2020 23:40
02-28-2020 23:40
Is it the Versa2 Bluetooth that doesn’t work under water?? I have seen several earphones - eg AfterShocx Bone conduction earphones - made specifically for swimming. You mean they wouldn’t work with the Versa2??
Best Answer02-29-2020 06:05
02-29-2020 06:05
Bluetooth doesn’t work under water. Swimming headphones use Bluetooth if you are head out breaststroke swimming. You can listen to built in music storage underwater.
02-29-2020 06:06
02-29-2020 06:06
i360 headphones. UK company. Need to have had out of water though to listen to Bluetooth. Can store music on them to listen underwater.
