02-25-2019
11:46
06:56
MarcoGFitbit
02-25-2019
11:46
06:56
MarcoGFitbit
Hi, I am hoping someone out there can help me out...as Fitbit support seem to have been failing for the past six weeks...
So I have a Versa and Skullcandy headphones. Initially this worked well, but after a couple of weeks, the watch couldn’t connect to the headphones, sticking at the ‘Pairing JIB Wireless screen’, with rotating blue lines. So I assume at this point the watch or the headphones are faulty...test this out. Watch connects fine to other Bluetooth devices, speakers etc, so it must be faulty headphones...except they connect perfectly well to my phone/IPad etc.
I raised this with Fitbit support over a month ago, and they are ‘looking into it’.
Any ideas?
Thanks in advance.
Best Answer02-26-2019 07:02
02-26-2019 07:02
Hello @GLPNE73, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. At this moment, if your headphones are not connecting to your Versa, I would like to suggest you the following:
When pairing is complete, a check mark appears on the screen.
I hope this can be helpful, give it a try and let us know in case you need anything else.
Best Answer02-26-2019 08:33
02-26-2019 08:33
02-26-2019 08:44
03-06-2019 12:45
03-06-2019 12:45
I have exactly the same issue between a Versa and Skullcandy headphones....for a few weeks they connected via bluetooth and it worked great, but then without removing the headphones as a device they were no longer connected and no matter what I try I cannot connect them. The Versa does "see" the headphones and tries to connect, but I just get the spinning "connecting' message that never ends.
Hopefully there will be a fix soon.
04-17-2019 20:27
04-17-2019 20:27
ine does the exact same but with sony sp500 headphones
