01-03-2019 16:02
01-03-2019 16:02
I am trying to connect my headphones to the versa. Went here for a solution before posting tried the posted solution multiple times. Still not working. Need more help.
01-03-2019 18:05
01-03-2019 18:05
I have beats that can't be found by the versa, even though its next to it, also my Samsung tab2 can't find my versa.
There should be away to shut down the versa and start it up again. I haven't tried this yet, but will try it.
01-03-2019 22:01
01-03-2019 22:01
There are two ways to shut it down.
A complete shutdown through settings, hello.
How do I restart my Fitbit device?
01-03-2019 22:03
01-03-2019 22:03
01-03-2019 23:47
01-03-2019 23:47
Think I might do a factory reset, as I was able to connect before the update. Now it's not working. The shutdown doesn't work. I unpaired some headphones and now theywont connect either now.
01-04-2019 10:57
01-04-2019 10:57
Any advice for me?
@Rich_Laue wrote:There are two ways to shut it down.
Troubleshoot a problematic device by turning it off and then back on
01-04-2019 11:16
01-04-2019 11:16
01-05-2019 11:37
01-05-2019 11:37
I believe that the fitbit are accepting the in ear ones, but any type that are over ear then they are not for some reason. I have messaged customer support on Twitter. Hope they help.
I have connected some in ear ones, but don't want those ones. They need to update the fitbit to allow these.
01-05-2019 12:42
01-05-2019 12:42
I have now found that if you hold the on/off button it actually works and have now managed to connect them to my versa. It might be the same with the bose headphones.
