12-20-2020
01:46
06:23
JuanJoFitbit
12-20-2020
01:46
06:23
JuanJoFitbit
Hi good morning I have two fitbit versa one is not working its locked and I cannot use it now. Another one glass broken but it's functioning even I cannot use because of glass broken. What should I do can I change broken glass to locked fitbit. Please reply
Moderator edit: format
12-20-2020 07:51
12-20-2020 07:51
Hi @Seenamol
Welcome to the forum. I'm sorry to hear you are having some issues with your Fitbits. If you have a place that fixes broken mobile phone screens, they will likely be able to fix your Fitbit screen. I'm not sure if they can take the screen off of one tracker and put it on another, but it's worth asking an expert.
Best of luck!
