11-19-2018
12:18
08:13
HeydyF
11-19-2018
12:18
08:13
HeydyF
Movements of my arm seem to trigger the display to show. Yet if I repeat the same movement the display doesn't always come on. What is supposed to trigger the display to show?
Best Answer11-19-2018 12:40
11-19-2018 12:40
@Peter52 as I mentioned earlier - the same arm movement that you normally perform to check time on the watch. Lift your arm up, twisting your wrist so you can see Versa's display. It's not always perfect.
11-19-2018 12:23
11-19-2018 12:23
@Peter52 pressing buttons, tapping the screen or an arm movement like you wanted to check the time. The last one can be switched off by pressing and holding left button of Versa and setting Screen Wake to manual.
11-19-2018 12:27
11-19-2018 12:27
Understand but what arm movements? As I stated, moving my arm to view the usually triggers the display on but not always. Is the speed or direction of the movement used? This is not really a big deal but it would seem if the display comes on doing a certain movement then doing that movement again does not, I would like to know if there is a movement that works most of the time. Yes pressing the button works but if you have something in your hands, that isn't always possible.
11-19-2018 12:40
05-22-2019 21:37
05-22-2019 21:37
Yes! Thanks so much! My versa was driving me crazy as had stopped coming on with wrist movement but the settings had been changed (probably as my two year old likes to press all the buttons!) I’ve now altered it and it works again 🙂
Best Answer05-23-2019 17:55
05-23-2019 17:55
@Mummyshark I'm glad I could help! 😄
05-23-2019 18:20
05-23-2019 18:20
Excellent, thank you for sharing this update @Mummyshark. ![]()
You can find more information about this feature here as well.
Let us know if you have further questions!
