10-13-2019 23:31
10-13-2019 23:31
Is there a possibility that the charger could be broken?
I have tried plugging it into other USB ports and even connecting it to multiple wall power sources. Not my battery is depleted and my Versa is useless.
Can I get my money back on this product if it is within its 2 year warranty?
10-13-2019 23:33
10-13-2019 23:33
Hi @Melis2fit have you tried cleaning the contacts on the device and the charging unit? That would be the first step. If you're still under warranty, Fitbit would work to fix the problem or replacing the device and/or charging unit, but a refund would more than likely not happen. Try cleaning first, then see if it charges and let us know.
10-13-2019 23:40 - edited 10-13-2019 23:41
I have cleaned it MULTIPLE times. I have tried wiggling the charger and the USB. It doesn't react at all.
This is the second watch after it has already been replaced.
Will the shop replace it immediately, they are normally fussy? Because I cannot use my watch at the moment. It's completely dead.
Best Answer10-13-2019 23:44
10-13-2019 23:44
@Melis2fit not sure on the speed of replacement, if they determine it needs to be replaced. You in the UK? You'd need to get with customer support and I have numbers for the US and UK. Other than that, you could do an online chat to reach them.
10-14-2019 00:17
10-14-2019 00:17
Thank you for your responses. What else can they do to erect the problem? Because the watch is useless now.
I am in South Africa.
Best Answer10-14-2019 00:23
10-14-2019 00:23
If you're not in the USA or if you prefer an online chat or email, then click for contact options
Sorry I don't have a number to help you. You can reach support at Facebook or Twitter, too.
