02-12-2019 08:39
02-12-2019 08:39
How accurate *IS* that count? Versa claims I burned 140 calories during a 45 minute barre class, but when I using a Charge 3, it was lower (but it could be because the Charge 3 doesn't HAVE that mode and I was only basing it on the graph?)? Like half the amount?.
Thanks
Best Answer02-12-2019 16:27
02-12-2019 16:27
@writergal28 going by the number it seems pretty accurate to me. Out of curiosity, which exercise mode are you using to track it? Yoga or Pilates? It also depends if your barre workout incorporates aerobic exercises (contradictory to plain Pilates).
02-13-2019 05:56
02-13-2019 05:56
It was the "workout" mode. Versa doesn't have anything else by default. I'm also really tiny - about 95 lb (give or take) at just under 5'2". I assume that I burn less compared to a more "fit average" size person
Best Answer02-13-2019 19:48
02-13-2019 19:48
@writergal28 you're correct. The 'larger' you are and the less fit you are, the higher calorie burn. A few tips: you can rename the workout in the Fitbit mobile app to Custom Name (i.e. barre). You can also try manually starting a similar type of exercise e.g. yoga. I would probably stick to workout though due to cardio elements in barre. Good luck!
