05-19-2018
07:55
11:18
DavideFitbit
05-19-2018
07:55
11:18
DavideFitbit
My Fitbit says I burned 1000 calories during a 1,5h powerwalk.
This cannot be accurate, can it? But it's also confusing to me that a newer version like Versa would be so wrong.
Can I trust the calories burned?
05-20-2018 03:55
05-20-2018 03:55
Check that your correct height and weight information are in your profile.
Best Answer05-20-2018 05:04
05-20-2018 05:04
They are, I checked it. Any idea what else could make the calorie burn be so off?
Other people I've asked, that use other types of fitbit or other brands, say that when they go for a walk for as long as I did, it shows they burned around 4-500 calories, not 800-1000. But how could the latest and "best" fitbit be so off? Doesn't make sense to me.
Best Answer05-22-2018 01:06
05-22-2018 01:06
Hi, I am also having the same issue.
personal data is correct however my tracking of calories is off. Way off. Did you manage to come right? If so, how? Thanks so much Courtney
Best Answer07-14-2018 21:35
07-14-2018 21:35
Mine is doing the same thing. I went for a walk, just over an hour long and it says I burned 936 calories. realistically it was half that. I double checked my height, gender, weight and they're all correct. Any ideas?
