06-14-2021
12:22
19:02
EdsonFitbit
06-14-2021
12:22
19:02
EdsonFitbit
As per fitbit my calorie burn is too high when I walk and low when you do intense cardio. Especially when it autodetects I'm walking. I did 70 minutes (64 zone minutes & 129 avg bpm HR) of pretty intense Bodyweight HIIT workout which tracked under activity Circuit Training and my fitbit showed 314 calories burned which I believe but then a 67 minutes walk (autodetected) at a moderately leisurely pace gave me 286 calories burned at a 99 avg bpm HR.
06-14-2021 19:01
06-14-2021 19:01
Thank you for visiting the Fitbit Community, @arpitabhardwaj.
Thanks for the information provided.
In this case I would recommend restarting your Fitbit Versa 2 by following these instructions.
Please be aware if you track an activity that is not part of the list of exercise shortcuts like HIIT, your watch might try to estimate your calories burned but since this activity hasn't been tested by our engineering team, we cannot guarantee accurate results.
If you have any question, please let us know.
06-15-2021 12:10
06-15-2021 12:10
06-15-2021 15:56 - edited 06-16-2021 14:20
Thanks for your response, @arpitabhardwaj.
The restart process won't change the data synced to your Fitbit account but it will help your Fitbit Versa 2 to fix any possible malfunction.
Your watch should provide accurate readings when automatically tracking the following activities:
In addition, you can manually start the following activities from your Versa 2:
If you start one of the exercises listed above but track a different activity, we won't be able to guarantee accurate readings and wouldn't be able to tell if the readings are accurate because the device has not been tested to record activities other than those mentioned above. For information about how accurate are Fitbit devices, please visit this article.
Please let us know if you have any questions.
06-16-2021 00:33
06-16-2021 00:33
