Can I answer phone calls on my Versa 3?
ANSWERED
New to me iPhone 11XR. Can’t receive phone calls on versa3
1 BEST ANSWER
Accepted Solutions
Hi there, @GMAWOF01. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 3.
If you've switched your phone, please try the following steps:
  • Unpair your Versa 3 from your old phone's Bluetooth and also from the new phone.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your new phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 3 again.
  • Set up notifications on your Versa 3 again.
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
1 REPLY 1
