Can I charge my Versa 2 from a wall outlet?
Can I charge my Versa 2 from a wall outlet instead of a computer/laptop
2 REPLIES 2
Hi @Motley22 - generally any valid USB charger should work.
Hi there, @Motley22. Welcome to the Fitbit Community Forums. @Guy_ Thank you so much for your help!
Tips to best charge Fitbit trackers are:
  • Use only genuine Fitbit charging cables
  • Use only UL-certified wall chargers
  • Avoid USB battery packs
  • Charge at room temperature
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
  • A computer
  • A Wall A/C to USB adapter, commonly found with smartphones
  • A DC to USB adapter (vehicle power port)
