12-08-2021
01:32
10:13
AndreaFitbit
12-08-2021
01:32
10:13
AndreaFitbit
Hi, looking into buying a versa 2.
Can I download a c25k app to it and go running with out my phone?
I Have you run carrying my phone in my hand for my head phones to connect and use the app etc but would love to have a watch to do this so that I can use the c25k app and link my headphones
Is this possible? Or do I need to look at the versa 3
Thanks
12-08-2021 04:00
12-08-2021 04:00
Hello @Kitkate21 and welcome to the Help forum. There is a C25k app for the Fitbit smartwatches, but there are differences between the phone app and the Fitbit app. The phone app gives you audio feedback, but the Fitbit app can only give vibration feedback. There is another issue if you use the Exercise app on your current Fitbit to track your runs. Both apps must run in the foreground. You can use one or the other, but not both.
Getting a Versa 3 won't make a difference.
Have you thought about an armband or nice running belt instead of having to hold your phone?
Laurie | Maryland
12-08-2021 04:00
12-08-2021 04:00
Laurie | Maryland
12-08-2021 05:33
12-08-2021 05:33
Thank you so much, that's really helpful. I'm still using a fitbit charge which I've had since 2018 I think so doesn't do half the stuff a versa will.
I don't currently track any runs, I'm mostly a walker and do spin classes but want to run again hence starting with the c25k app. Vibration will be fine actually. Can I use an app for music? I tried a belt and an armband before but they got on my nerves and that was a previous smaller phone.
Really appreciate all the info! Thanks!!
12-08-2021 10:19
12-08-2021 10:19
Thanks for getting back to us and for sharing your questions @Kitkate21.
You can control music with Versa 2, Charge 2 doesn´t have this feature.
If you have a Spotify Premium account, access additional music controls by using the Spotify app. For more information, see How do I control music playing on Spotify?
Keep on visiting the forums.
12-08-2021 10:42
12-08-2021 10:42
@Kitkate21 I hope another user can chime in about real experience with what you are trying to accomplish. I always have my phone with me. I listen to Pandora and Amazon Music. The Pandora and Deezer apps on the Versa 2/3 requires a paid subscription and I'm too cheap. Fitbit doesn't support Amazon Music. Like I wrote, the C25k app must run in the foreground. I just don't know if you can control or change your music once you start the C25k app.
Since your current tracker is in the Charge family, I want to explain a little about Spotify. The Spotify app is a Connect and Control app. It connects to and controls music from your phone. You must have your phone with you.
The Versa 2 lets you transfer personal music (in theory). I put personal music on my Versa 2 a while ago. But it used 10% of the battery every hour and I didn't expect that. Every now and then a current Versa 2 users asks for help transferring music. They describe problems I never encountered. I stopped offering help.
The Versa 3 doesn't let you transfer personal music. A paid subscription to Pandora or Deezer is required.
I wish I could give you a step-by-step how-to do do exactly what you want, but I can't.
I also think an armband is annoying. I use a running belt for my phone and my stuff.
Laurie | Maryland
12-09-2021 02:08
12-09-2021 02:08
Thank you so much for taking the time to reply! All of that is super helpful! I have decided to go for the versa 2!! I was worried about making the change but looking forward to my new purchase thanks to all your information!!
12-09-2021 04:51
12-09-2021 04:51
Thanks for getting back to us and I'm glad to hear that the providedi information helped you deciding for a Versa 2 @Kitkate21.
You can check user's manual here.
