Can I edit a workout on my Versa 3?
I frequently forget to turn off my Exercise tracker when I'm done.  Every other exercise app I use allows me to go back and adjust the time when this happens. Since my Fitbit integrates with the WeightWatchers app I'm going to get credit for an hour long workout when I only exercised for 25 minutes.  Frustrating.
4 REPLIES 4
Hi there, @Hotpockets1975. Welcome to the Community Forums. Thanks for the details provided in your post. I understand how frustrating this can be.
You can edit or delete activities in your exercise history in the Fitbit app. However, depending on the exercise, you can choose to edit the type of exercise, start and end times, distance covered, and calories burned. Note that you can only edit activities in the Fitbit app. For more information, see How do I add, edit, or delete Fitbit data and activities?
Hope that helps.
Thank you for the information!  Unfortunately when I hit the 3 dots as suggested the only option I have is to delete (and it's the word delete not a trash icon) the workout or Export a TCX file. I have an android.  Thanks!
@Hotpockets1975 you can't edit activities in Android app. You may rename some of the activities (like Workout) but that's the end of editing capabilities.
thank you for the confirmation!  Guess it's time to try a better fitness tracker!
