04-06-2019
10:18
10:55
DavideFitbit
04-06-2019
10:18
10:55
DavideFitbit
Can I get the weather channel on my Fitbit Versa?if so how
04-06-2019 11:07
04-06-2019 11:07
Hi, a weather app is usually standard installed on your Versa. What do you exactly mean? If the weather app is not in the list of "My Apps", go to all apps and search for the weather app and install it on your Versa. Or do you means something else?
04-08-2019 10:21
04-08-2019 10:21
How do I install and manage apps on my Fitbit watch?
04-08-2019 10:26
04-08-2019 10:26
04-08-2019 10:57 - edited 04-08-2019 11:30
Hi, do you mean that your want to see the weather on the display of your Versa? Or do you mean the Accuweather channel/API? in the last case, when you type this in the search bar og All Apps, you will get the Weather app from Fitbit (see my first answer) cause this uses Accuweather as API.
