10-05-2019 15:01
10-05-2019 15:01
Hello! I just got my first FitBit, the Versa 2. I was hoping someone could tell me if I could sync (from iPhone Clock app) or add an app in which I could personalize the alarm. For example, I want to add a description to the alarm so I know what it is for, such as 11:15 pick up dog at vet. I want a more specific reminder than just for my phone to vibrate at 11:15. That doesn't help me if I don't remember what the alarm was initially entered for!
Any help is appreciated!
Thank you!
10-05-2019 16:00
10-05-2019 16:00
Sorry, but I don't think there is any way to do that.
10-05-2019 17:18
10-05-2019 17:18
Thanks for your reply. Disappointed to hear this.
10-05-2019 18:55
10-05-2019 18:55
I don't think you are talking about alarms but more reminders in your scenario.
If you set a calendar reminder on your phone (e.g Google Calendar) and have notifications active for such application, you will get a notification on your Versa at the time chosen.
10-06-2019 00:42
10-06-2019 00:42
@mishibish you might also want to vote for the feature suggestion to let us add labels to alarms:
https://community.fitbit.com/t5/Feature-Suggestions/Naming-Labeling-Alarms/idi-p/649861
Note though, fitbit's comment that they don't currently have plans to make this change. The more votes it gets the more likely they are to change their mind.
10-07-2019 04:27
10-07-2019 04:27
Thank you for all your replies. I will certainly vote for this feature to be added!
05-10-2020 12:08
05-10-2020 12:08
Use Alexa!
Make sure Alexa is set up on the Versa, download the app on your phone and go to the reminders section.
You can set a labeled reminder, to repeat as many times as you want each day - and you can set Alexa to "Announce from: Fitbit" only, instead of also announcing the reminder on your phone and alexa speaker, to keep some privacy.
Hope that helps!
