Can I replace the battery of my Versa 2?
Can the battery be replaced?  If I can, where can I get it replaced?
2 REPLIES 2
Hi there, @MomaKay. Welcome to the Fitbit Community Forums.
Please note that the battery on your Versa 2 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do it as it could permanently damage your watch.
Keep in mind that your Versa 2 was designed to last 6+ days, but this also depends on how frequently you use all the features of your watch. Said that, I recommend charging your Fitbit watch with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above suggestion, please check this help article for more tips and recommendations.
The battery is dead. Won't charge and isn't recognized by the app.
So I guess my watch is dead and there's nothing I can do about it, except
of course, buy a new watch?
Thanks
